YOU WILL NEED TWO 5 1/2 INCH LONG 1/4 INCH FINE THREAD BOLTS A FINE THREAD BOTTOMING TAP TO CLEAN THE HOLES FOR THE PULLER BOLTS AND A STEERING WHEEL PULLER . A 1 1/8 th scoket and a Long breaker bar , and impact would work far better to remove the nut . You are going to ask why such long bolts , well with most steering wheel pullers you can ot get both puller bolts into the holes in the wheel as they are closer then anything out there . So you have to sorta make the bolts flex a bit so longer is better . and like Pete said a good pair of snap ring pliers and once the steering wheel os off ya remove the snap ring and set the steering wheel back on and give a sharp har turn either way and that old seal will just pop wirht out and i use a deep well socket to install the new one and in a matter of lets say 30 min you should be done . I can do them in ten min. but i have replaced many and i know what i need to carry to the job . It ain't hard to do and if ya run into trouble ya know where Pete and i are for help
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
