Posted by Owen Aaland on December 14, 2009 at 16:13:05 from (65.165.246.148):
In Reply to: Farmall 460 Gas posted by jdiesel on December 14, 2009 at 12:38:38:
BenB said: (quoted from post at 16:38:38 12/14/09) I've got a 460 gas with a stuck engine that I am getting ready to put in the shop for the winter to get it up and running. The problem I'm having right now is that I cant get it to steer whatsoever. I know it has power steering and I'm wondering, do I need to take the lines loose or what do I need to do to be able to steer it? It's kind of hard dragging it around to the barn with my other tractor when the front wheels of the 460 are turned about 20 degrees to the left. Thanks for any help/suggestions!
Ben
The steering on a F460 is mechanical with hydraulic assist. When you say you can't get it to steer do you mean you can turn the steering wheel but the wheels won't move or things are so tight that you can not turn the steering wheel?
If the steering wheel turn free without steering the most likely problem is worn out splines on the shaft and yoke at the front end. If the steering is frozen so that you can not turn the steering wheel then you have problems in either the front steering gear or the front axle assembly.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
