Posted by Owen Aaland on January 03, 2010 at 13:52:37 from (65.161.86.2):
In Reply to: starter noise posted by ScottyHOMEy on January 03, 2010 at 07:27:36:
clint s said: (quoted from post at 12:15:39 01/03/10) A few things it could be. Starter gear not sliding out all the way, Starter gear worn, ring gear worn. Take it off and check. It will be obvious which one it is. Mine was doing the same thing a few years ago. I posted the pics below here an most people told my I would have to change the flywheel too, but I guess it looks worse in the pic than it is because I have never had a problem since I changed the starter. I got a remanned one for $119 from our host here and it was less than having mine rebuilt Notice how the gear on the starter is chewed up
This picture is good example of a damaged drive that will cause engagement problems.
If the flywheel ring gear teeth are burred over on the ends they can be cleaned up with a file or small grinder. The ring gear teeth do not necessarily need a bevel on them but it is helpful if they do. It is critical that the Bendix drive teeth are beveled on the non-load bearing side.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
