Posted by steveb05 on February 13, 2010 at 05:02:45 from (98.158.64.25):
In Reply to: 1948 Cub posted by FarmallZach on February 13, 2010 at 04:32:35:
Make sure you don't have a vacuum leak at the manifold or the base of the carb.Here is how I suggest you can check it turn the engine over and see if you have gas running out the carb.Then check the #2 or #3 spark plug to see if they are wet. If not you have a vacuum leak . Also if the battery is low on charge that can be a problem if you have a battery ignition. You may be pulling down the amperage with the starter and not have enough voltage to allow the ignition to fire the plugs Steve
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
