Re: '53 Super A oil leak from front crankshaft seal
Posted by aquanosis on February 13, 2010 at 12:58:12 from (67.241.20.22):
In Reply to: '53 Super A oil leak from front crankshaft seal posted by pete 23 on February 13, 2010 at 10:59:24:
gene bender said: (quoted from post at 13:25:19 02/13/10) You have to remove the steering sector first. Then use a bearing seperator to remove the pulley and you aint going to get it done in 4 hrs as you have to support the front so you can remove the radiator and steering housing as the pulley doesent come off without removing the steering sector.
Do I need to remove the front cover or governor housing or is the seal removed simply from behind the pulley after it's removed? Farmall Parts.com has what's called a Front Main Seal part #FP24638. Is this the part and are any other washers or gaskets needed? Thanks
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
