Posted by john taipale on March 04, 2010 at 18:45:01 from (209.105.184.45):
Had engine rebuilt by reputable engine shop that does top notch work. Put engine back on tractor. Had distributor rebuilt. Placed engine in top dead center. Two notches on flywheel at pointer. Piston in cylinder one visible at top. Also stuck finger in plug hole to verify compression stroke. Put distributor on - lined up correctly. Verified spark from distributor by taking #4 spark plug out and watching for spark on each compression stroke. Made sure new plug wires going to correct cylinder in 1-3-4-2 firing order. Rotor rotating clockwise. Took off distributor cap and removed plug #1 and with finger in #1 cylinder hole watched rotor rotate and compression and rotor position and all appears to be correct. Put the plug back in and dist. cap back on and tried to start. Had sprayed starting fluid in cylinders. Starting fluid in carburetor air intake. Choked, turned on start switch; and no firing! I'm stumped. Any insight will be appreciated. Thanks John :)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
