When you install the distributer, the rotor is supposed to point to the #1 terminal on the dist cap. I think you said that. Turn the distributer counterclockwise (viewed from the rear) when installed, then rotate clockwise until you get a spark from the coil wire. Confirm by rotating the engine one turn, 360 degrees, you should get another spark from the coil wire. Provided the carb is set up right, it should start. If not remove the air cleaner hose from the carb, place your hand over the carb inlet and crank with the starter, you should feel strong suction. If you don't you have a manifold leak. If you get suction, and the timing is on, you have some sort of a fuel problem. Also, you indicated double notches on the pulley, the pointer is supposed to line up with the first one.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
