Re: Hydro 86. Trans Troubleshooting
Posted by Owen Aaland on March 12, 2010 at 17:13:22 from (198.70.47.146):
In Reply to: Hydro 86. Trans Troubleshooting posted by Matt Compton on March 12, 2010 at 16:32:58:
The most likely cause for the tractor not moving until you move the lever back and then forward is a snap ring that has come off the shuttle valve. Another possibility is too much wear in the lever and quadrant. Hold the lever to the side as you move it forward to check for this problem.
As far as not being able to stall the engine, that is normal. In Low range the hydro should be able to overcome the brakes. In High range the brakes should be able to hold enough to open the relief valve. Once the relief valve opens the load on the engine will decrease so you will not be able to stall the engine.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
