What Bob is saying is to use a socket smaller than the inside dia of that yoke and it will bear against the end of trans input shaft. I am wondering , how much play do you have on that shaft, up and down, if any amount you are basically wasteing your time putting a seal in . I almost always pull the whole input shaft assembly so you can do it right. More than likely the pilot bearing inside will be shot and both ball bearings on input shaft are loose. If you have a belt pulley attachment , you need to take that off also if doing this,(then throw the whole thing away and put a plate one top, I hate them darn things). Don't attempt to put input assembly back in without being able to make certain pilot bearing is getting into input properly. Just my way of doing things. I am going to add something else here. What I have seen several times when someone removes yoke and reinstalls it from underneath, is that the half moon key comes out of place, crawls up out of keyway and thus damaging the yoke. Just be extra careful that key stays in place.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
