Posted by sflem849 on April 04, 2010 at 19:40:01 from (69.197.84.192):
In Reply to: starting prcedure WD9 posted by Janicholson on April 04, 2010 at 18:02:32:
Janicholson said: (quoted from post at 18:02:32 04/04/10) That is definitive.
You are going to need to have the seals in the pump worked on. it could be literally cracked or broken. it should have engine oil only in the chamber, too the check port you mentioned. I would not try to run it any more until the pump was repaired. It might be clear what is wrong with it by taking it apart carefully on a bench, but shops might not work on it is it has been taken apart casually. (There are good diesel pump shops, I do not have a contact for a good one, the archives might provide a good source. Jim
I just got my MD injectors redone at DIS in Windsor, WI. They were very reasonable at $200 each with new valves and new everything in each. The Central Diesel guy would have been about 50% more than that, but I hear he is VERY good.
Too bad Sask is so far away, I would LOVE to have a WD-9. Bad pump or not. They are no big thing, only money. Couldn't it just be a bad lift pump seal causing inj pump dilution? That is a super cheap shot in the dark if it is a possible cause. No timing or any other stuff needed, just a $5(?) gasket.
This post was edited by sflem849 at 04:32:24 04/05/10.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
