Jim - Actually a relay NOT required if you use the old light switch on 12 volts!
Compared to 6 volts lights, running 12 volt lights cuts the current through the switch by half. So the current load through the switch becomes much less.
The original light switch on first ever 12 volt conversion - done on my Super M nearly 30 years ago - is still working fine.
Only difference now is the dimming coil sees half the normal current. It hence now is less effective at dimming the lights. IE on the "dim" setting the 12 volts lights will burn somewhat brighter than OEM lights do on "dim" on 6 volts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
