Re: partially wired H for 12 volt.
Posted by lspencer001 on April 09, 2010 at 14:24:52 from (24.164.70.48):
In Reply to: partially wired H for 12 volt. posted by Bob M on April 09, 2010 at 14:01:46:
Bob M said: (quoted from post at 14:01:46 04/09/10) Jim - Actually a relay NOT required if you use the old light switch on 12 volts!
Compared to 6 volts lights, running 12 volt lights cuts the current through the switch by half. So the current load through the switch becomes much less.
The original light switch on first ever 12 volt conversion - done on my Super M nearly 30 years ago - is still working fine.
Only difference now is the dimming coil sees half the normal current. It hence now is less effective at dimming the lights. IE on the "dim" setting the 12 volts lights will burn somewhat brighter than OEM lights do on "dim" on 6 volts.
OK thanks very much.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
