If it will roll with the clutch down, it is in gear. All the shifting gears except High Gear are sliding gears splined to shafts. High is a sliding spline coupling input to output (direct) If it is in a low gear first or reverse, it would be hard to turn the engine with the wheels. the engine is probably stiff. I will bet the trans has had a shift fork wear out, and get out of place. If the 1-R rail will not move, I bet that that fork is bent, or out of place. Pulling the top shifter cover off might let you see better just what is going on. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
