Posted by mkirsch on May 21, 2010 at 09:36:30 from (64.80.108.56):
In Reply to: SH Hydraulics posted by cuylarbergie on May 21, 2010 at 08:01:03:
Assuming you're talking about a transport disk harrow, and that you want to lift it out of the ground...
One-way means you have pressure up, gravity down. Works fine for transport disks. All you need to do is figure out which hose causes the disk to go UP, and hook that to the port on the right side. Remove the DOWN hose and replace it with a vented cap, which you should be able to get from any machinery dealer.
That is the cheapest way to hook it up.
If you want pressure-up, pressure-down, it will run you about $200-$250 for the valve and hoses.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
