There are some possibilities. If the coil is connected to a ballast resistor, the there may be a second connection on that terminal. It should go to the starter relay I terminal (four terminals two big, two small One small is a S the other is an I. If it is hooked any where else, or something is tee'd into that wire it might cause it. If the Voltage regulator input (ARM terminal) is connected to the ignition in any way it will cause it. (that wire has only two connections, one to the Arm terminal, and one to the Gen Big terminal. If the ignition controlled anti Dieseling Fuel shutoff solenoid on the carb is wired wrong, it might feed back into the ignition.
Trace the voltage with it running but OFF, and find its source. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
