Re: 806 Rear axle....
Posted by Owen Aaland on June 01, 2010 at 20:52:59 from (65.165.246.77):
In Reply to: 806 Rear axle.... posted by Dan Swanson on June 01, 2010 at 06:42:54:
To decrease the end play in the axle you will need to remove shims. BUT if your axle is loose it is because you have a bearing that is failing. You need to correct the cause, not just address the symptom.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
