Is there a correct cold/hot oil psi for 656 Gas?
Posted by TX656 on June 05, 2010 at 09:01:13 from (69.34.243.195):
On a fresh overhaul (turned mains and rods) I have 43PSI at start up and 22-23 PSI HOT pulling disk. This is on a 95 degree day at 1400 RPM.
I have the blue ribbon manuals and can find no PSI specs in them.
Mechanic friend did the reassembly for me (after I jacked up the first the I split it) said the machine shop did a wonderful job and the clearances were now spot on per the blue ribbon manual.
Oil Pump has been overhauled and there is a new pressure relief spring and all new metal check valves in the oil filter housing.
I was expecting more like 80 PSI cold and 40 hot (nothing to base that on except some car engine overhauls.)
Thanks
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
