With 30 weight oil you should have around 40 psi hot at high RPM. There are a couple gasket designs for the oil filter base over the years and you have to make sure your new gasket matches the filter base not the block. An incorrect one will cause low pressure. Also adding the new metal valves in the filter housing can cause trouble as the seats in the pot-metal base wear and the new metal valves don't seat correctly. Its best to find a cast iron filter base from an earlier 560, much better design.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
