Posted by sflem849 on June 06, 2010 at 20:22:11 from (69.197.84.192):
In Reply to: Farmall H, 4th Gear posted by Janicholson on June 01, 2010 at 17:36:58:
Janicholson said: (quoted from post at 17:36:58 06/01/10) There are combinations of gears in several transmissions that can fit in that trans incorrectly. It might be easiest to find a donor tractor in a salvage yard and swap out the two gears. as a set. Be careful to assess the condition of the Fifth gear splines on the 4th/5th slider, and the input shaft. They are often toast on tractors that have been raked into 5th from 4th 20,000 times. They must have clean straight sides and little wear to be sure of having a good fifth gear. Jim
Should you be able to take off from a stop in 5th? Without winding it up and dumping the clutch? :S My MD and H certainly can't do it and I wouldn't want to try on my SMTA.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
