Posted by D Slater on July 17, 2010 at 17:53:07 from (72.65.148.95):
In Reply to: Starter issue posted by SCOTT300IOWA on July 17, 2010 at 15:42:36:
When the switch is turned to the start position check to be sure power is getting to the small wire terminal at the selonoid. If so its probably a bad selonoid. If not check the terminal at the switch that energizes the selonoid. If no power there its a bad switch. If power there its a problem with the wire from ignition switch to the selonoid. Or try a jumper wire from the battery cable side of the seloniod to the small terminal. (Don't know if thats how you're jumping it or across the 2 big terminals) If it turns the problem is the ignition switch or wireing. Not uncommon for those key switches to go bad.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
