Posted by scott#2 on September 05, 2010 at 20:03:40 from (138.88.81.129):
Well after looking for the last hour for a gallon of way lube that I know I bought from MSC, I think I accidentally used it in the super a when I changed the engine oil after the big snow. After I changed it, it was put away and I havent run it since.
I know I received the way oil, I found the packing slip along with some other things from MSC but can"t find the oil.
Since I havent run it since, except to drive it to the barn, I"m thinking that it"s most all drained down into the pan and all I need to do is let it all drain out and change the filter.
Wonder if way oil would have any affect on the new front neoprene main seal or anything else in the engine? It"s a much higher viscosity, high pressure lubricant
What a dumb a$$, any thoughts? Think I should change the oil out 2 times to get it all out, run it in between?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
