Re: Second day of cranking the A
Posted by ScottyHOMEy on September 30, 2010 at 19:55:20 from (71.241.193.87):
In Reply to: Re: Second day of cranking the A posted by Enar on September 30, 2010 at 19:43:13:
Another idea, related to fuel. Where you've had the carb off and been painting, too. Check out the gasket between the carb and manifold, and that they are torqued god'n'snug together. Same with manifold-to-head if you had that apart.
An air leak in any of those joints could make for the problem you're having. An easy test (Okay, not so easy if you're cranking by hand, but . . . call it part of the charm of the old darling) once yu're sure the ignition is squared away, is to crank while spraying a combustible around the joints mentioned. If it fires to run it means it is taking on fuel from a leak in that intake joint, which robs your carb of the vacuum it needs to do its job.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
