Re: 300 TA Adjustment
Posted by pete 23 on October 27, 2010 at 21:23:36 from (184.12.32.90):
In Reply to: 300 TA Adjustment posted by Bouncer on October 27, 2010 at 20:42:06:
TA adjustment won't bother you while not running as far as shifting into or out of gear. Worn out or messed up shift lever and rails could or bearing out of transmisson top shaft. TA adjustment amounts to , free play on direct drive clutch of about 1/8th to 3/16th inch movement of TA release shaft and then adjust link between clutch and TA so it moves immediately when pushing clutch pedal and releases ta same amount as pulling ta lever. What you are trying to acomplish is full release of the 7 inch dry direct drive clutch so planet gears can revolve freely and allow rollback of transmission gears to relieve tension of load.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
