Posted by dpski on October 28, 2010 at 05:38:09 from (128.222.37.58):
Argghhh..... Please tell me it"s just air in the system and it will work it"s way out.
Finally pulled the starter rod on my Super C last night after months of work. It was a happy moment to hear it run again, except to my surprise the hydraulics are not working. This project started with a leaky radiator, months later and countless hours later of preparation, paint is dry and ready to put the wheels back on.
Of all the things I disassembled, fixed, and re-assembled, to many to list here, you guys know the deal, the hydraulics were the least of my worries upon startup, because all I did was disconnect the FastHitch hydraulic lines. Already rebuilt the hydro pump last fall with new O-rings 'cause it was leaking into the crankcase. Drained and refilled the whole system and cleaned the screen as well last fall. All was functioning just fine when I shut it off before this project started.
I topped off the hydraulic fluid, been using Case/IH Hy-Tran. I worked the levers, both the TouchControl and the remote FastHitch cylinder lever back and forth a bunch of times. Took the TouchControl hydro unit filler plug out during all this hoping to see some fluid movement and/or let any air in the hydro unit escape, nothing.
I greased all the TouchControl arms before painting because I didn"t want the paint to get in-between them and bind them up.
I"m at a loss for all I disconnected was the remote FastHitch lines and the rods from the TouchControl levers. The hydro unit, pump, and metal tubes to/from pump to hydro unit remained intact during all this.
I"ll try it again tonight and hope it"s air stuck in the system, but anything else I can try or check?
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
