I"m at a loss for all I disconnected was the remote FastHitch lines and the rods from the TouchControl levers. The hydro unit, pump, and metal tubes to/from pump to hydro unit remained intact during all this.
I"ll try it again tonight and hope it"s air stuck in the system, but anything else I can try or check?
Thanks[/quote]
You say you left them intact, but did you drain the fluid from the reservoir? If you did, the pump is probably not primed. If you did not drain it, you will need to check for system pressure like El Toro said.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
