Posted by Owen Aaland on November 08, 2010 at 21:34:32 from (65.161.86.17):
In Reply to: 350 LP transmission posted by tleake on November 08, 2010 at 11:41:14:
Is the noise there with the clutch released in neutral? If it is you probably broke a tooth on the constant mesh gear in the front of the transmission. You can remove the belt pulley drive assembly or cover plate to see inside the transmission.
If the noise is there only while moving the problem most likely will be in the final drives or ring and pinion gears. Don't overlook the possibility of of a loose wheel causing noise.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
