Posted by Wardner on December 15, 2010 at 19:09:05 from (4.154.254.210):
In Reply to: 400 3rd hyd valve posted by 1950MFD on December 15, 2010 at 16:31:17:
Well there are a couple of reasons:
1. The first valve in the stack always goes to the rear remotes and it is cheaper to plumb from the back side for that valve. Plus the guys on the assembly line didn't have to cope with the tin shroud.
2. The first valve is different from the other two. It only has two service ports. The opposite side single port is used for the PS U-tube.
3. The back side of the two outside valves are covered with the lever bracket for all three valves.
4. The manifolds for the outer two valves need to exit to the front to simplify the mid-tractor hydraulic outlet position. Those four steel hydraulic lines take up alot of space. Why complicate all that spaghetti with two more ports?
There are probably a few more reasons but those come to mind. Just pull back the shroud and have at it. It shouldn't shorten the remaining time you have left on this earth.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
