Posted by Haas on January 07, 2011 at 06:55:39 from (75.216.143.189):
In Reply to: Pulley Seal posted by S/C Bob on January 06, 2011 at 17:12:05:
I don't recall for sure, but I don't think there is a drain on the pulley housing. You don't need to remove the pulley housing to replace the shaft seal on the pulley. Remove the bolts that hold the flange behind the pulley mounting flange. The pulley shaft assembly will then pull out. You will need a press to remove the gear and bearings to replace the seal since the seal has to come off the far end of the shaft. There is no gasket on the mounting flange, just shims to adjust the gear lash. Make sure you clean the shims up and put them back like you found them.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
