I'm thinking there is some confusion on when this battery voltage is being read. A battery that reads 11.9 volts with no load on it, has not had a heavy load on it for at least a few minutes or so is basically a dead battery and will not crank an engine. Now if you are reading voltage while cranking that is a whole different situation. Anything over about 10.5 volts would be considered good cranking voltage. It boils down to open circuit voltage versus loaded voltage. Like pointed out, 12.6 volts on a battery that has not seen a charger for several hours would be considered as a full charged battery. If it has been on a charger, weather running in a vehicle or separate battery charger , the surface voltage would have to be removed by a light load for a minute or so and then allowed to settle out again. The old lead acid batterys were rated at 2.09 volts per cell,normally just rounded up to 2.1, however, the maintence free batteries will some times run a little higher as they may be lead calcium plates or some derivitive thereof. Next thing is if you have one bad cell that can throw off the total open circuit voltage to give erronous readings. Takes more than some one reading a voltmeter to determine condition, all reading must be interpeted. I have heard good things about the new type of battery testers on the market, but I understand they cost $600 or so for a good one. I use a carbon pile load tester along with good voltmeters and hydrometers for my work.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
