Re: Winter Battery Storage
Posted by jdemaris on January 20, 2011 at 11:46:04 from (67.142.130.14):
In Reply to: Re: Winter Battery Storage posted by pete 23 on January 19, 2011 at 19:27:39:
A fully charged 12 volt flooed-lead-acid battery - when it is at its highest capacity - has 2.15 volts per cell. Not 2.09 volts. An absorbed glass matt battery near the same.
A fully discharged 12 volt FLA battery has 1.9 volts per cell.
You check battery voltage at the battery when it's been at rest for awhile. Not right after cranking or charging. Finding a battery reading 11.9 volts right after cranking means little. If you come back 15 minutes later and it still reads 11.9, it's almost completely discharged (or defective).
A healthy 12 volt battery if sized correctly will drop to 9 - 9 1/2 volts when cranking the engine over. If it drops below 9, there is a problem - e.g. a bad battery, bad wiring, bad starter, engine problem, etc.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
