Posted by Janicholson on February 03, 2011 at 19:15:16 from (67.72.98.45):
In Reply to: 1949 MD Sleeve Failure posted by Sleeve Failure on February 03, 2011 at 19:06:03:
Best Guess on my way of thinking is thatthe sleeve was loose in the bore (too loose) and cracked around the top ring allowing the sleeve to drop down. as it dropped the top ring expanded above it and made a snap ring effect pulling it down into the crank case. Engines hate that, and puke sleeve fragments till they stop. It should not be a tough repair. Use service manual information on the sleeve fit. If you find the other sleeves are just fine, and want a single sleeve, LA Sleeve (on line) has them, or can make them easily. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
