Re: 300U Manual Steering Right Side Sloppy
Posted by Janicholson on February 17, 2011 at 06:14:06 from (199.17.6.194):
In Reply to: 300U Manual Steering Right Side Sloppy posted by Dellbertt on February 17, 2011 at 04:06:34:
From my experience there are straight spurr gears in the box that are directly meshed with the shaft from the opposite side. Even if it had play in and out, the gear teeth mesh would not be adjustable. A broken tooth would make a radical difference in play (pretty common) and wear would also be a factor. See if it has the same play when near the right or left full lock travel. (not at full lock) if it doesn't, there is an issue of wear or tooth damage in the center of the partial gear on tha loose shaft. If the play is along the whole length of the travel, the key might be loose at the arm taper.
Be sure to look closely at the shaft to arm joint for movement. The parts diagram on caseih.com does a pretty good job of illustrating the components. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
