The original coil had no resistor, the tractor was 6v from the factory. The ceramic resistor is now to be removed entirly. The wire from the on off button is now connected to the negative side of the new coil (assumes positive ground of battery and probably a generator) the positive side of the new coil connects directly to the distributor side terminal. If it has an alternatoe and is negative ground (probable if it is an alternator, check battery polarity) the ignition wire connects to the positive couil terminal and the negative connects to the distributor. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
