It does help. If the Starter relay is a 4 terminal affair. the wire connected to the I small terminal is connected to the coil or resistor on the coil side. This supplies starting voltage to the coil as a bypass (as I was having you do in my post). When the key is turned back to run, this wire is disconnected. Thus the coil is now dependent on the ignition switch and the wire to the resistor, and the resistor. Resistors fail. Jumper it as I indicated, and try it. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
