Posted by Janicholson on March 19, 2011 at 09:32:34 from (199.17.6.194):
In Reply to: Thunder volt coil posted by redgems on March 17, 2011 at 21:04:20:
try some stopleak (I like subaru OEM from their parts counter) The hotter coil omly makes the necessary voltage to fire the plugs. So a coil able to produce 100,000 volts will only make 13,000 to fire the plug! Thus a good coil will make 20,000 easily. Do not waste you money. I would recheck the valve settings, put valve stem umbrella seals on the stems (can be done by removing the rockers, then putting about one foot of cotton rope in the cylinder, then raising the piston by hand to hold the valves shut, then removing the retainer and spring to put on the rubber umbrellas.) Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
