First check the single to double action settings on the aux valves. One may be turned too far bending or breaking the roll pin and that will cause system to stay on demand. The 560 is not really a true open center valve system as there is no flow through aux valves when in neutral, the flow from the pump is diverted to reservoir through the regulator valve ( unloading valve). This valve is controlled by a screened orfice under the cover of reg valve. If plugged or peened undersized it will cause your system to stay on demand , fluid going over relief valve portion of regulator valve assembly. Clean or replace orfice if plugged. More information on other posts previous to this one.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
