Well I was able to open up the valve and cleaned it out. The screen was a little gunky but not too bad, but it could have been plugging up those small holes at the end of the screen. I also cleaned up the inside of the piston chamber as best that I could but I could not for the life of me get the part with the ball in it to come out. I made a small spanner wrench to unscrew the ball valve but I couldn’t get it to unscrew! I bent the tool which was hardened steel, but it didn’t budge. I did push on the ball and oil came out and I cleaned it all with carb cleaner and the ball seemed to be doing its job and holding even the thin carb cleaner behind it. It wasn’t rusty so I put it back together. As soon as it stops raining for more then 1 day I will be able to try it out in the field and see if its working right now. I also adjusted the draft control which was set wrong and causing the 2pt hitch to be pressurized when it was all the way up. But I know I wasn’t running it all the way up when the problem occurred. At least it’s cleaned up and adjusted right, Ill let you know if it keeps happening.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
