The stock pump is for "one way" (pressure lift, gravity drop) hydraulic operation only.
It MIGHT lift your drill if you connect it like this: Connect the hose from the blind end of the cylinder to the front port on the right side of the tractor. Then remove the hose from the rod end of the cylinder and replace it with an air strainer fitting. However the pump may not have the pressure and oil capacity to fully extend the cylinder under load.
A better alternative is to install a 4-way hydraulic spool valve. Supply it from the same pump port as above, and plumb the return line back to the dipstick tube. You will now have 2-way (power in both directions) hydraulics.
However depending on the condition of the pump you still may not have sufficient pressure to lift your drill.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
