Re: Super M engine id
Posted by D Slater on May 12, 2011 at 03:59:14 from (184.15.43.86):
In Reply to: Super M engine id posted by Scott Bontrager on May 11, 2011 at 19:18:38:
Probably you see listings for C264 engine kits. C264 engine was also used in SMTA and 400 tractors. Serial # break for what aftermarket refers to for piston sets happened during 400 tractor models.
Check the engine block above the oil filter and above the metal cover on the side of block. Should find a raised casting # 356980R1 and also C264. If another casting # or its ground off the engine block was probably changed, 356980R2 counts as a change. Block serial number for a SM engine is often found stamped in just above the steel cover on the right side of block. closer to center of block from front to rear.
After all the years and changes that could be made it pays to take engine apart if possible before getting parts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
