Posted by horsepoor on May 14, 2011 at 12:06:56 from (208.124.126.217):
Hydraulics on the Farmall 240 are getting too hot. I recently had a problem with the teledepth valve sticking and causing the pump seal to blow out. Puts the hydraulic fluid into the crankcase. Pump has been repaired, and I replaced the teledepth valve body with a hydratouch valve. The way it is set up now, there are two hydratouch valve bodies on the left side of center, and a block with no fittings then another hydratouch valve with remotes on the right side. I assume that I am not getting enough flow to keep it cool, or running too high of pressure. Any thoughts?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
