Posted by Owen Aaland on June 03, 2011 at 04:32:18 from (216.47.33.198):
In Reply to: 686 coolant in the oil posted by Erik Dekeyser on June 03, 2011 at 04:11:24:
Look carefully around the outside of the bottom of the sleeves. It is very likely that you have an O-ring leaking. With O-rings it is not only how many hours on on the engine but also how many years since they have been changed.
Most likely you will have to remove the cylinder head and then if you are able, you can remove the sleeve and piston as an assembly. If the block and sleeve look good you could make a satisfactory repair with just replacing the O-rings.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
