Re: farmall C cast #'s
Posted by Cliff S on June 08, 2011 at 16:58:07 from (64.136.26.227):
In Reply to: farmall C cast #'s posted by Lo hp ih owner on June 08, 2011 at 16:36:25:
The Block you Have is a Super C Block and will Accecpt the 3 1/4 Pistons!
This will Give you 133cid and with the Right Parts to go with the Bottom end you Can Acheave Between 29 up to 50+ HP depending what you Want To Do!
I Have Ran This Combo in a Super C On the NATPA Curcut and Won a few in 3250 Div 3 with 14.9x36 Cut Tires!
I Also Have a Tamer Verson in a BN that Runs 13.6x28 Non Cut tires !
Frame weights are Knot Needed unless you plan on useing a Fast Hitch equitment etc and Farming !
You Need Weight Brackets So you can Adjust your weights For Pulling !
Cliff S
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
