Posted by mkirsch on June 15, 2011 at 05:34:24 from (64.80.110.75):
In Reply to: CLUTCH ADJUSTMENT posted by KEN IND. on June 14, 2011 at 20:56:59:
I agree with rusty... Owner's manual is CHEAP to buy, INVALUABLE to have.
Still, the clutch adjustment procedure is extremely simple on an H. All you do is unpin the linkage up front, loosen the lock nut back at the pedal, and adjust it so there's about 1" of free pedal play measured flat out from the top of the platform.
It may be too late for your clutch, though. Someone had to run the clutch with zero play for a LONG time to get to the point where it's slipping. That's hard on the clutch and throwout bearing.
Luckily it's pretty easy to change the clutch on an H. You can do it without splitting the tractor, unless the flywheel really needs machining.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
