Posted by big a on June 16, 2011 at 20:54:25 from (166.223.250.134):
Been tearing my hair out with this. Engine hi idle speed will only make about 1650 rpm. Made all adjustments according to I&T manual, replaced governor spring. Still no change. It acts like it needs to be able to stretch the spring further to get more RPM, but the arm inside is maxxed out on travel. It is actually hitting the front of the governor cover, the high idle adj screw is backed out, and not touching the stop.
Removed governor and disassembled and inspected things, expecting everything to be totally shot. To my suprise, it is in great condition, bearings good, weight pin holes tight, thrust washer, bearing and sleeve all good.and tight.
It operates good and governs well, just too slow. Throttle is synched with the linkage and not binding. I can grasp the throttle linkage and speed up the engine, so I KNOW it will run faster.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
