If you are speeding it up to no load rpm by hand below the vent cover and the external and internal lever is to maximum travel with stop bolt backed off? Its still not adjusted correct, worn linkage, spring still weak, binding governor bearing sleeve or incorrect parts. Make sure the fork and bearings from spring to throttle linkage moves free on piviot shaft.
Also check that a power unit governor wasn't installed in the past.
Also did the old spring have a yoke and pin?
This post was edited by D Slater at 06:35:55 06/17/11.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
