Posted by LRRifleman on June 19, 2011 at 07:46:19 from (72.61.244.83):
Hello!
I have a 1958 International Model 340 Utility. Back in the summer of 2009 I had to replace the sediment bowl, which was heavily corroed and the "neck" looked like swiss cheese. Yesterday, while disking a field, my tractor developed a fuel delivery problem. I did a band-aid fix on the filter, and pulled the sediment bowl. There wa a high degree or fuel corrosion within the neck and petcock assembly. This was an aftermarket sediment bowl kit from Tractor Supply, and will be temprarily replaced with once since TSC is open on Sundays, and my local Case/IH dealer is not. I need to finish disking the field and get my equipment home (I am leasing some land on another's farm).
My questions:
1) Are the newer, non-IH sediment bowls in need of a schedled replacement?
2) How can I reduce or minimize (if not eliminate) the the corrosion within the sediment bowl/petcock assembly?
As an aside, the carburetor was just rebuilt this past winter, I do not see that as being suspect ... more the filter and petcock assembly.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
