Re: Farmall 300 Hydraulic Pump Seal
Posted by IH fan on June 27, 2011 at 06:00:59 from (99.103.254.184):
In Reply to: Farmall 300 Hydraulic Pump Seal posted by BruceS. on June 26, 2011 at 04:49:40:
F.K. said: (quoted from post at 07:26:46 06/27/11) Oil pump shaft and seal appear OK. Could a faulty safety valve block possibly be causing excessive psi and blowing by the good seal in the pump to the crankcase?
Not being familiar with most individual models of tractors, I don't know where a pressure test port might be, but it most likely has one. Find that and install a guage, probably one capable of 3000psi will do. Again, not sure what a 300 system pressure might be, but I'd check that agaist the specs... someone here no doubt knows what that is, but being a gear pump from that era (1950s), probably no more than 2500psi. Run your cylinder to the end of the stroke (dead-head it) and read the pressure. If it's noticably higher than the spec, that could be the problem. That's about the only way you can tell anything... put a guage on it.
This post was edited by IH fan at 06:02:06 06/27/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
