With a charged battery. Turn on the key and measure the voltage at the distributor terminal. If voltage, turn the engine till the points close. (No voltage there now) Then measure the voltage at the coil terminal connected to the ignition. If it is 12+ volts you need a 12 volt coil no resistor needed. If it is between 8 and 6 volts you need a coil made for use with a resistor. Some of the IH tractors had a resistor built into the wire going to the coil, it is actually the wire, and not obvious. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
