Posted by c1802362 on September 03, 2011 at 18:45:30 from (72.195.142.179):
A neighbor told me a few weeks ago that my '41 H was idling fast so today I decided to check things out. I took my handy dwell/RPM meter and hooked it up to the coil posts.
I got no reading.
However, if I hooked up one lead to the distributor, the meter read approximately 1100 rpm. To my mind this is a bit wierd, but .... Following the serviceman's instruction's book, I started changing the idle adjustment and stop screws.
Moving the idle stop screw did nothing. Turning the idle speed adjustment screw fully clockwise (screwed in completely) reduced the meter reading to about 850 rpm, but the engine seemed to run a bit rougher and lacked a bit of power.
I went back to my dwell/RPM meter and realized it works only with 12V systems - my '41 H is a 6V tractor.
So, I've probably messed things up.
My question: Do I need to get a dwell/RPM meter that works for 6V or is there another/better way to set the idle speed correctly? Any other suggestions?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
