If I understand correct, with the sparkplugs removed the engine still has a tight spot I wonder if the engine run good after started? If so the valves and valve train is probably okay and maybe the pistons. May want to check the main and rod bearings for wear. Wear pattern should show if a crankshaft or rod is bent or block bearing bore off. Also maybe a bent cam or other shaft bent that bind the front timming gears. Also do you mean the timming was one inch from mark and you changed it?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
